Dumb question... mounting batteries
BlkGS
Melbourne, FL
Heres the dumb question of the day.... how much room is there underneath the battery compartment in my 07 sx230? I was I investigating my boat and found neither battery is actually mounted, they're in plastic holders that are not screwed to the floo. I want to fix this for my upcoming install. So how much depth do I have down there for screws? Obviously I am paranoid about hitting something vital or going into the water. What's underneath it?
Thanks for the help.
Beachbummer
Houston TX
If you see the screws come out under the hull....you had less room than you thought!!!!! (Sorry could not resist)
Mine seems to be attached with some sort of rivets, but I won't be there again until next weekend. I'm sure someone else will give you better info!!!
Best of Luck!
the MfM
Glue a mounting board and screw the battery trays to the mounting board. Or just glue the trays in place.
Betik
Frisco, TX
I have a 2012 240 and mine has at least 0.5 inches.
@Bruce provably knows the answer to your question; he has his ratchet starpaped for th bimini crossings
Bruce
Royal, AR
I am trying to remember how long the screws I used were. I installed two battery boxes, cut the hooks off of ratchet straps and used stainless tie down points through the straps with likely 3/4” screws to hold them down. I also put screws through the supports under my refrigerator. The flat section is double hulled. The whole boat is.
If you use 3” deck screws it will make for a funny post followed by using epoxy and gelcoat to repair the mess.
buckbuck
Texas
Who has that infamous picture?
BlkGS
Melbourne, FL
That's exactly what i want to avoid, haha.
Thanks for the input. 1/2" should be plenty, may go even smaller for the amps. Or I may make them a little board for all the wiring too. Not sure yet.
MissScarlet
I used half inch SS screws....no issue......as in nothing like this:
Newbie question -- I've never attached anything to my boat. Is there a need to pre-drill for these 1/2 inch screws?
seanmclean
Medford, NJ
Predrill anything going into glass or gelcoat.
MissScarlet
THANKS! I was thinking that, but wanted to double check. I'll be installing a second battery, Blue Sea's "Add a battery" switch/ACR, a new stereo head unit, LEDs, and an amplified bazooka tube this weekend! Can't wait to get this thing on the water!
bronze_10
Raleigh / Wake Forest Area..
When installing this batteries... remember.. if u push the batteries close to the outside wall u have less room under them... closer to the inside is more room !
