MattFX4
- Marietta, GA
- Other
- Other
I'm in the process of putting my boat in a wet slip and ran in to an issue I didn't see coming. I was hoping I could keep my battery charger connected at all times, but the marina told me that only approved shore power cords can be used. It is 30 A/ 125 volt outlets on the dock (picture below). I have found adapters to go from 30A /125 to 15A/110 which would power the charger. My issue is i don't know if that is technically safe. Run a shorepower cord from outlet below in to boat battery compartment, and then use an adapter to plug the charger in. The guy at the marina said the boat should have a shore power inlet. This is new to me, so I don't know where to go. I'm going to be bummed if I can only plug in my charger while I'm there at the slip with the boat.
