Electrical short help
SeaRay
Had a short. Left my son alone in boat he hit start button and melted hot wire from battery to solonoid across to starter hot wire into the ground on starter. All of that melted. Any ideas on the cause or damage to the electrical system beyond starter and solonoid.
Rakkaone187
Burnsville, MN
Something I’ve learned on this forum that will get you responses, provide the Year, Make, Model. Whether you are running any aftermarket equipment or if stock OEM setup. Explain the issue: (which you’ve done), explain what you’ve already tried, and any other information that will be helpful: pictures of damage, info about where you were, lake, salt water, on trailer etc.
Beachbummer
Houston TX
That's a great point, the starter may have shorted internally. With all power off and Main switch off, maybe check continuity between red wire spot to starter and ground. If the is no resistance the starter may be shot and shorted.
SeaRay
Its a cheapo amazon. Im mainly worried about if the juice could have travelled into the ignition system. Yikes
Beachbummer
Houston TX
What a cheapo? Starter? Solenoid? Button?
Not many melted wires on this board, you owe us a picture :) (only kidding a little bit)
SeaRay
That's a great point, the starter may have shorted internally. With all power off and Jason switch off, maybe check continuity between red wire spot to starter and ground. If the is no resistance the starter may be shot and shorted.
Its shot now. Its crispy. That boy hammered it lol. I know i need new wires starter and solonoid. I just hope i dont need stator paks etc etc.
SeaRay
Amazon 100 dollar. Its 175 sportjet. I was ohmtesting the stator inspecting it. Put a new rectifier on it soldered some connections then hooked back up and solonoid was buzzin on start. Boy 6 year old. In there pretending to drive and stuff. I already took to mechanic i gave up. Im pretty sure i hooked everything up right. When i went in house he hammered the start button and she went crispy
SeaRay
Starter was cheapo
Beachbummer
Houston TX
In theory the current path for the short is separate, hopefully only the parts you listed. a big breaker might have saved you, but most boats don't come with one. Good item for winter list.
Beachbummer
Houston TX
Wow! Thanks for that!
Should buff right out.
I see the starter is in the extended position and engaged to the plate. The incoming big red wire looks a little suspect too, but hopefully not terrible to replace/repair.
Best of Luck, keep us posted!
SeaRay
Yea i guess when my boy hammered it. It popped up after he put enough juice to it. Lol
SeaRay
Got her runnin. Ran new wires. New starter. New solonoid. Put a new blower motor bunch of crimpin and solderin. So i got her goin for time being. Thanks for the help
