Bill D
- Prairieville, LA
- Limited S
I finally got my emergency bilge pump install finished today. I call it an emergency pump because it will run on a float switch that is installed about 8" above the bottom of the engine compartment. I want it to function only after the primary pump cannot keep up. I also installed a light and buzzer at the helm to let me know that the backup is running. There is a bill of materials at the bottom of the thread.
Here you can see the bilge pump and the Water Witch 101 float and the 2,000 GPH pump. The angle of the photo makes it a little difficult to see, but the switch sits near the top of the engine mount support structure.
The pump requires a 1 1/8" outlet hose. I ran a new dedicated hose to its own outlet. I ran into a little bit of a situation when I tried to run the outlet. On the LS boats, the shower tank sits right in front of the original bilge outlet and shower vent. The problem with the shower tank is that you only have about 2-3" of clearance between the tank and the hull. So, the through-hull fitting would not have room for the hose to attach. There is a nice part... the shower vent is only a push-through type and requires less depth. So, I chose to relocated the vent. I moved too fast to take a complete before photo, but you can see where the vent originally was, where the second outlet went, and the relocated vent.
I wired the pump and alarm circuit to the Aux panel I located in the battery compartment. The panel is wired to the house battery switch. If the switch is on, the panel is live. I used a relay (that's the black box with the blue and yellow wires coming out of it) to activate the alarm. For the alarm I used a simple buzzer/light combo.
Here is the panel and relay.
And the alarm. It is located under the helm. I also utilized a spare switch for a "silence" function. I figured if the worst case scenario happened; the boat is taking on water, both bilge pumps are running, and we have to figure out what to do... the last thing we want is a buzzer chirping at us.
2,000 GPH Bilge Pump - https://www.amazon.com/gp/product/B00N6I1DCM/ref=oh_aui_search_detailpage?ie=UTF8&psc=1https://www.amazon.com/gp/product/B00N6I1DCM/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Water Witch Bilge Pump Switch -https://www.amazon.com/gp/product/B00CMWLHX8/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Bilge Pump Plumbing Kit -https://www.amazon.com/gp/product/B004XACR90/ref=oh_aui_search_detailpage?ie=UTF8&psc=1https://www.amazon.com/gp/product/B004XACR90/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Black Thru-Hull Fitting - https://www.amazon.com/gp/product/B000N9NWZ8/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
14AWG Wire (for pump power) - https://www.amazon.com/gp/product/B00MI59JD4/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
18AWG Wire (for alarm and aux circuits) - https://www.amazon.com/gp/product/B0154MAECC/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Alarm Buzzer - https://www.amazon.com/gp/product/B00Q1B2730/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
