Has anyone removed the anchor chain?
rad1026
Albuquerque/Havasu
I know, I know, the chain is an important part of the anchor system. Our local lake is a mud pit. I pull up the anchor after sitting in a cove for a while and have 10 lbs of clay on the chain that takes a half hour to clean off. Its a PITA. Its also a pain to get in the boat without scraping something. If we are just sitting in a cove for a while is the chain really going to matter that much?
Believe me, my trusty danforth has saved the day many times so I know it has to do its job.
tabbibus
Lake Lanier, GA
your trusty danforth will stop being trusty. If you wanna get rid of the chain get a box anchor
Beachbummer
Houston TX
have you tried dragging the anchor while in the water to wash it off?
If you take the chain off, worst case the anchor hold is compromised and you have your answer. There is certainly a point where the anchor holds with chain that it won't hold without it, but how to know exactly when that is for you? I think you will only find out for certain by trial and error. If it's such a pain, I would try it without the chain in your position.
All else being equal, the more rode, the more holding, so maybe compensate with more rode and try it?
This is sort of what I do when I pull my anchor covered with NC red clay. I pull it up well off the bottom....live visible in the water, tie it off on the cleat, then leave it there with the anchor locker open(so I don't take off with it down). Then I drive slowly out from the raft location and get into open water, then go pull it up the rest of the way. It is always clean by the time I pull it up. JUST DO NOT FORGET IT IS PARTIALLY DOWN!!!!
Chatt_Jetsetter
Chaparral
VRX
You could get rid of the chain, just thread a 10lb weight onto your rope about three feet from the top of the anchor. This isn't actual advice of course, but it might work! :winkingthumbsup"
RobbieO
Sacramento River Delta
212SE
Get and anchor buoy and pull your anchor up with it. It will clean it at the same time.
RobbieO
212SE
Ronnie
SF Bay Area
I do most of my boating in the rivers of the Sacramento Delta which has a muddy bottom and is usually shallow, less than 30’ deep. My rig hasn’t had any chain on it for years. Just a bungee line (anchor buddy) that stretches to 50’ or 75’ and a box anchor. I can’t remember the last time this set up has failed to hold my boat in place on the first try. The box anchor is awesome and easy to pull up, just get right over it before you do.
