Welcome to Jetboaters.net!
I have been using my 2005 ar230 all summer and recently one motor want start in the water but runs fine out of water with the water hooked up to it any ideas has new plugs and was serviced right before summer
Hopefully it's not a compression problem. I don't know how many times you put the boat in/out of the water to test it but it might have nothing to do with being in the water. Does it crank? Could also be an electrical issue like the safety cutoff switch or the clean out plug hatch switch.
That being said, if you're going to pull the coils you might as well check the compression while you are there. You can get an inexpensive set from Harbor Freight or you can borrow one for free from Advance Auto.
It will start out of the water with water hooked to it but as soon as I put it in the water it just spins over and want fire. My right motor starts and runs fine the left motor is having the problem only in the water
Pull all 4 plugs
Remove lanyard
Push fast neutral button
Apply full throttle
Hook up compression gauge
Crank for 2-5 seconds until the pressure doesn't go up.
Release the pressure
Repeat test at least once per cylinder.
Post results.
30 minutes max and that includes uncovering and covering.
Not a bad idea to spend $20 and put new plugs in.
If one cylinder is low, add a few mL oil and retest to see if it's the valves or rings.
Let me guess, number 3 was low? It sounds exactly like what happened to me. If so, it's bad exhaust valves and seats.
You could try to start it with the neutral button and enough throttle to minimize vacuum during cranking and finish off the season.
That's number 1. There are valve shims. You need to remove the valve cover and rotate to tdc, then buy thin feeler gauges. Measure all the them and compare to the specs. If they are oos, then pull the cams, lift the little cup thing, measure the shim, then determine what thickness shim you need to get you back in spec. Pita. The machine shop charged me 200 bucks and i was stoked i didn't have to do it!
Here is the head with no cams. The shims are under those shiny cups.
I rotate the engine with the valve cover off here.
