@help on the water. Ignition does nothing when turned. Battery showong 12.6 volts. Tried jump pack....nothing. all electronics work.
dscable
Crawfordsville, IN
Kill switches ckecked. Plug is in. Clean out plug is in
Beachbummer
Houston TX
Jiggle fnr lever
Dave burke
Near Lake Placid
Do you have two batteries? If so, is the start battery switch on?
Scottintexas
Corinth, TX (DFW)
fuses in the ECU, under the circle cover ,
anmut
212S
Is it turning over or not turning over at all?
Turning over: check kill switch
Not turning over: start at battery, check fuses / relays / switch wires
Scottintexas
Corinth, TX (DFW)
if your electronics work it's probably not your ECU fuses but worth checking anyways,
I would jiggle the throttles and work the cleanout hatch switch,
It would be very unusual for your actual key switch to go out,
What were you doing before this happened? hanging out anchored? tubing and you stopped to change riders ?
Chief
Lake of the Ozarks, Missouri
242 Limited E-Series
Double check both the lanyard kill switch and the stern hatch kill switch.
Make sure it is in nuetral.
anmut
212S
I'm thinking that because he hasn't replied, he may have got it started... :)
Scottintexas
Corinth, TX (DFW)
and for future reference the @ help (all together with no space) only sends out the special alert if you use it in the body of the post,
putting it in the title line doesn't send the alert,
also, the safety lanyard cuts the spark, the engine will still turn with the starter with the lanyard out,
the cleanout hatch safety switch will disable the starter also so the engine won't respond at all ( in case you have your hand down the cleanout tube)
Chief
I think the safety lanyard creates a no crank condition on the E series...i will confirm tomorrow night.
Dave burke
Near Lake Placid
thanks for the clarification @Scottintexas. I never realized the @HELP had to be in the body of the post. Is that a system limitation? Because up until you told me, I would have instinctively put it in the subject line to get maximum attention.
Scottintexas
Corinth, TX (DFW)
I don't understand how any of it works, ;) only the instructions say to put it in the body to send the signal, I say do both,
and by the way, even though you just activated the alert signal by using the function, I didn't get the alert on that either,
what about you @tdonoughue ??
tdonoughue
The Woodlands, TX 77381
Nope. Got notified you mentioned me, but nothing from the help tag... Shall we let @Bruce know? Oops. Already did...
Dave burke
Near Lake Placid
Oops, didn’t mean to do that. Could it be because I replied to your post?
dscable
Crawfordsville, IN
All. Thank you so much for your replies. I just got service back. Ended up being starter cable loose. Tightened it up and started right up. Here on the lake for the week so we will see if it happens again. This forum is awesome. Sorry I couldn't reply individually to each of your suggestions. Thank you!!!!!!!
sunbyrned
Louisville, KY
I'm glad that you're out of this situation safely . I'm wondering if with these at-help situations, (afraid to write it out correctly) that some type of constant notification or limited access on the forum to the person who made the post could be implemented until the case has been resolved. That way we all can learn from the situation and get better at identifying the issues and we have some peace of mind of the outcome. (?)
