Trevor Shipman
- Charlotte, NC
Sorry to use the @HELP feature but my brother (who isn’t on this forum) but I share our boat with, is helping his neighbor trying to become a fellow jet boater.
Long story short, they went and looked at a 2012 AR240 today. It’s def a bit more beat up than they expected. On the hull there are some decent marks, some showing fiberglass. The fiberglass exposed areas didn’t seem soft, just exposed. He rates the hull at a 5 out of 10.
The boat has also clearly been used in salt water which the seller didn’t mention (lives prolly 2/3 hours from the coast. Some areas are etched like the steering column and on the engines. Rust spots on the typical areas of a sea boat as well.
The major issue which is why I called help is the starboard engine killed out twice when the owner hammered the throttles. Not puttered out, but as if you pulled the kill switch. The quickly cranked the engine back on and she fired right up again. This happened 2 out of the 5 times they “hammered it”. When both engines were going she ran like a dream. LOTS of power, good rpms.
So right now they are at lunch to discuss wha to do. The issue is, the boat is priced really well at 25k. Hard to determine if they are buying a 25k problem boat or a 25k boat that just needs a little money and love?
Any input on the engine killing out? Walk away? Or if you could get the seller down to 23k or less is there a “this too good of price” to walk away?
