Evildwarf
- Woodstock GA
- Limited
I store anchors rope etc in the starboard bow under-seat locker.
I placed some foam padding on the carpet and then the anchors sit in a shallow plastic tray that catches some of the water from the wet anchor gear. Decent set up.
But, the entire arrangement: foam pad, tray, and gear will slide backwards into the under-helm storage area whenever a hole shot or other high speed shenanigans occur.
No big deal but I would like to secure the anchor locker so the gear doesn't migrate.
Option 1: no high speed hijinks (NOT AN OPTON)
Option 2: secure the locker contents with some kind of fastener arrangement into the hull.
Option 3: ????
Any learned advice on putting a screw into the compartment floor or other ideas?
I certainly do not want to be that guy that drills through the hull by mistake.
Option 3: ????
