Is there a way to disable the shallow water warning?
eticket
Hi Folks,
I boat in a lot of shallow water and the warning "beep" is continually going off and annoying everyone. I have figured out that if I hit the right button on the tach with the depth gauge showing then the noise stops. However, it starts right back up again.
Has anyone disabled the warning on a 2015 212x (short of a physical change)?
Thanks,
Eticket
eticket
@Julian - thanks and your leading to to this manual got me off my lazy butt to search this out in the boat manual (which is in the boat, but can be found online with a bit of effort). You get into the System Menu, option 5 for calibrations. Push M and T simultaneously to set the water depth for the alarm. M for decrease, T for increase. Push M and T together again to save the setting. I will try tomorrow for real!
I forgot you have the Connectx screen on your boat! Glad you were able to figure it out!
