robert843
- Myrtle Beach, SC
Really only the weight of the boat is in the bed. The weight of the fifth wheel is being supported by the caddy so I would say he is fine with the weight on the truck.Probably the little trailer at the end is what makes it a problem lengthwise.
I wonder if the tires of the pickup are rated for that weight. That boat likely weights more than 3000lbs to need dual axle.
Yep, They can usually tow close to 20,000 lbs.I stand corrected. These big pickups can carry a lot!
4,162 to 4,346 lbs f350 payload.
