Jet ski watering battery question
jlcj7
Tega Cay, SC
Slightly off topic but question for jet ski owners. My battery didn’t even make it one year I charged it back up but have a question on water level. Are these lines (red lines) to indicate the water level in a battery?
You can see the dark color is where it is currently. C041BEAB-D0E8-4ECD-A9D0-0E4AB1AFEFAC.jpeg4AEC1F56-4127-48B7-8B6E-52A882F329E0.jpeg
Cobra Jet Steering LLC
Vendor
Florida
Yes fill each cell to the line this is why the battery is not working correctly once you fill it the battery will come back to life
Vendor
Florida
I use bottled water not tap water never had an issue .
jlcj7
Tega Cay, SC
Perfect. Thanks very much for the reply.
Neutron
New Bern, NC
You are supposed to used distilled water because it won't cause buildup on the plates causing it to lose life.
I had those batteries in my 2 skis go low all the time. Almost every month. So i got rid of them and got sealed AGM batteries and problem solved
jlcj7
Tega Cay, SC
Thanks. I will probably switch then once this one is completely dead.
Vendor
Florida
You will probably get another year out of it.
captras
Lake Livingston, Texas
Highly recommend! AGM so no need to check fluid, 18 month warranty, great customer service. Bought these for both my jetskis and very satisfied
www.chromebattery.com
