- Panama City, Fl
- Other
Because the nozzles turned inward is just a portion of what makes our system work. Plus 99% of the other boats out there cannot achieve this due to some limiting geometry inside the nozzle. To make it work you have to remove the nozzles from the boat and mount the nozzle in a specially made jig. Machine away a specific amount of material and then reinstall on the boat. Then you'd toe in the nozzles approx 7 degrees on each side.New to the jet boat thing and was wondering..If the thrust vector wake does the same as the nozzles turned inward, Why buy the TVW and not just leave the nozzles turned inward?
When all that is done you still don't have a dry ride for tubing, you still have a washy surf wave and the steering around the dock is not any better than pointed straight.
Our system gives every Yamaha boater the benefit plus much more.
