I was looking into this a couple years back......general consensus was the lights hindered your visibility often....either by a general washout of light in front of you or a reflection off the bow seats......not sure the source......maybe @Julian was part of that chat ?
As stated in the post I never use them while running, only while docking or parked on the sand bar looking for something or playing in the water at night.
I couldn't see anything with my lights while underway, but a better light bar may be different. I just usually take my spot light and use that, I also have a chart plotter and I mark things in the water that I want to miss.
Shinning on the water is going to be way different. The water reflects the light and makes it kind of " foggy" look. Best was I can think to describe it. If you are in an area and just no wake speed, it would probably do the job, just not for 20 mph.
Assume you know this, but generally running at any speed above no-wake with lights beyond running lights is a no-no.
I use a hand-held spot, flash on for a second or two to scan in front of me, then shut off. Rinse, repeat as necessary.
Note: I do this when moving through clusters of mooring buoys, not crab pots, so situation is not identical.
Yeah maybe that's the best option a handheld spotlight. Why can't you run at higher speeds with a light bar? For other boaters? I kinda figured I'd get a dimmer for passing other boaters
Yeah as I figured, my dad has a bright spotlight on his boat and it's on a dimmer so you dim it a lot passing boats but you don't shut it totally off so you vanish haha
I am looking into get the Hand held FLIR for my phone. http://www.flir.com/flirone/
I played with it at the boat show this year and was very impressed.
I've driven my Dad's bout and brothers boat at night plenty of times. Both are more equipped than mine (lights, radar and Gps) I was just figuring out the right light for my boat. Maybe I just get a small gps instead idk lol I love the thought of a Lightbar up there. Obviously just using it when needed so others don't get blinded. I found and RGB one that may be cool to use with a controller for cosmetics as well as functionally.
Good article! Explains well why you would not want to run at night with a light bar....regardless of how tempting it might be. I've been on the receiving end of boats shining their spotlights on me, and also boats running with no lights and they are a PITA! Fortunately in the latter situation I was on my brothers Grady White with Radar, and I knew a boat was there, just couldn't see it as he was fishing with NO lights on in front of the Sunshine bridge at the mouth of Tampa Bay!! (MORON)
I've only used it on lakes, but helps with navigating around the shoreline and docks. Just a suggestion. I like the FLIR camera for the phone, but can't see the justification for the price...yet! Might have to look for some more "reasons".
