- Royal, AR
- SX
Have you thought about using the 12v aux pin on the 7 pin trailer plug (assuming you have one) to provide add'l charge
Yes I have. I could use it while trailering but keeping the single battery in the truck charged is more important to me than charging the boat batteries.
Even if yamaha added it as an option to deal with the bilge pump checking, so what, one or three nights of checking is nothing, but if something goes wrong and water does start leaking in, those panels won't power the pumps
Surprisingly the bilge pump will run the battery down even though it is not pumping water. Instead of using a float switch it spins up the pump to check for water. The small panels on the E-series should be sufficient to counter this. You are correct that solar panels are not a reasonable way to power the bilge pump if it is pumping water.
