I don't see why not I have went down the clam river in MI in 3 feet of water for miles, the ramp and dock were definitely not any deeper. Never had any issues besides a little bit of grass from the surface of the water shooting out when I shot the water out of the box.Hi guys, I'm getting a used AR192 '14. I have a home without a dock yet. It looks like the depth is like 2-3'. Would that work for the time being? or likely get stuck?
Thanks
I've got a future 195S coming, and my dock guy said the most important thing is to have the right depth for the LIFT and NOT THE boat. While the boat has a very shallow draft, the lift apparently needs a sufficient depth for its mechanism which will be under the boat and its shallow draft. Hope I'm describing correctly - soon to be new yamaha boat owner...
Any issues with your sling lift affecting the boat hull? I have heard sometimes they can deform the hull, and although I LOVE my boat, Yamaha don't have the most sturdy of hulls.My lift, which is pictured in my profile sits in 2 feet of water. The key is to use a sling lift . Therefore, you literally only need 20 inches to get your boat in and out. The slings I use are good up to 10,000 pounds. They also do a great job of naturally making it easy to get it in and out and keeping the boat level. The steel lifts are more expensive and needs substantially more clearance.
I've got an AR190 and very shallow water at my dock. It averages around 2 ft but last week it was barely a foot and a half and I didn't have any issues at all other than my boat going under my dock platform when tied off. As far as lifts, I think the only thing that will work for a stationary lift is a sling style. Pretty much every lift on my lake is a sling. I am considering a floating lift. I've be talking with some dealers and they seem to to indicate that they will work in my depth range but I've avoided those that have air pumps to raise/lower the platform since I'd assume that would create an issue with depth. Also, as some folks have mentioned, pay attention to the lake bottom. I'm lucky, all I have is packed sand without any rocks or other debris to suck up. I keep an eye on the water leaving my boat and its always clear.Hi guys, I'm getting a used AR192 '14. I have a home without a dock yet. It looks like the depth is like 2-3'. Would that work for the time being? or likely get stuck?
Thanks
Might work....would depend on the bottom composition....wouldn't want a rocky bottom or it might punch holes in the Airdock (linked in my signature).Didn't @Julian have some sort of inflatable soft lift? I gotta think that would in a situation like this.
Also, is @Flowing is inactive since Oct 2021.....so not sure it matters.
