My FSH 190 won't go pasy 22 mph
Tutankhamun
Please help! My fsh 190 sport 2022 won't go past 22 mph. Am I doing something wrong?
What Rpm's are you running at that speed?
In addition to @Can0n11 question I would add, has it always only gone 22 mph?
You have to run the blower for 5 minutes then switch on the turbo. Standard stuff for the 190, if that doesn't work you prob have a bad impeller.
Yes from the start....I only use it for 8 hrs. To be honest I thought that is standard and when I finally decide to take to the dealership my 1 year warranty past and they wanna charge me 200$ just to take a look at it
I really didn't payed attention to that because I thought it was normal at 22
That is super important to know. It could be as simple as the throttle cable having too much play in it.
Just to confirm, your boat is a 190 FSH Sport and not a 195 FSH sport?
190 sport
Is the boat ready for you look at right now? Or away in marina?
The boat is at my house
Go under and take some photos of the impeller blades. Then hook up a hose and see what it revs up to RPM wise at full throttle.
I dont see where you responded with the RPMs? Also what is your standard load on boat. How many people and gear? Sounds like either overloaded or high altitude as the 190's are under powered anyway.
I have 2 extra batteries for the trolling motor and most of the time there's only 2 people on board
Altitude where you boat? Your RPMs are needed to troubleshoot whether its a pump issue or engine issue.
Pull clean out plug and clean the rubber ring. Check for debris in clean out and also the intake grate “sticks, rope etc…”
