- Royal, AR
- SX
I am hooking up a Raspberry Pi to play music for the boat but have noise in the signal whenever it is powered from the boat. If I draw power from an external source there is no noise, only minimal static.
Previously I experienced similar noise using a Fusion Bluetooth adapter and a Sabrent AirPlay adapter. The Pi introduces the lowest noise of the three.
In the video below I start with the Pi running from a USB battery pack and there is no noise. Then I plug it into the boat and the noise starts. Then I unplug and the noise goes away. Finally I replug and the noise is back.
I either need to replace my USB power supply with one that will filter the noise or filter the noise before the power supply. The Pi will be powered from a USB power supply inside the console. I used the one on the dash for the video. The in console power supply is connected to the stereos power leads.
I appreciate your advice.
@David Analog, do you have any tips?
