UnorthodoxCreations
- Hanover, PA
I purchased this 1999 LS2000 a couple weeks ago. Appearance wise it seems to be in great shaped. Seats are pretty much flawless, windshield are good, the hull is in great shape and everything seems really clean overall. I'm supposed to be the 3rd owner. The guy I bought it from had it for about a year. He said could never get it to run right. Both engines would stall if he tried to get on them hard. Both engines start pretty quick and seem to run fine though I haven't let them run for more than 20 seconds or so because I don't have a hose near where the boat is sitting for now. Compression on all cylinders seems to run from about 85 to 90 psi. I know that's on the lower end. Would you rebuild the top end before running this next season or do you think I could get one year out of it? Do you think the compression will come up any if I get a little run time on it or should the rings be free just from me messing with it? I don't think it's run much at all in the past year. My preliminary plan was to pull the carbs and look them over real well, rebuild if necessary and see how she runs. Unfortunately I live almost an hour from where I can put this in the water so when it comes time to be testing I can't running back to my garage quickly.
Here are some pictures and I have some additional questions below.
The engine bay seems quite clean. Looks like all the oil lines have been replaced. They are nice and soft and are clamped well on the carbs.
It has a single battery setup. Though I don't see myself having a lot of lights or big stereo that would drain the battery it seems like a second battery might be a good idea for peace of mind.
Is this speaker original or an option? It's mounted under the starboard console. It looks like there was also under the port console though it's no longer there.
Does anyone know what these wire would be for? The one with multiple wire seems to be tied into the stereo but I don't know what it might have been hooked to. The wire with the big metal end seems like coax. It runs up to a metal fitting on the top of the hull but it's cut. Maybe some sort of antenna?
Are these front speakers original? They match the rears but I thought I read front speakers didn't come on the LS2000. The stereo is the original Kenwood but I can't get it to work. It just says PROTECT on it. The manual says that is caused by a speaker short but I unplugged the 4 round speakers and it still says that.
Is this cleanout plug holddown original? I've seen lots of talk of them blowing out. This seems very secure but haven't come across another like it. Didn't know if it's a kit made by someone or homemade?
Any other comments, tips, etc would be appreciated. My experience is with Jet Skis. This is my first boat. Honestly I won't be doing much with this till spring as I promised my wife I would finish renovating our house first and that will probably take till spring. Then my plan is to try and get this thing running well, then start modding. I'd like to add a wake tower, maybe thrust vectors and it will get a wrap to update the graphics since that is what I do for a living.
