Yea I had some cavitation issues !!! And when I had ballast in the boat the factory impellers didn't like it ! LolBased on the condition of your factory impellers I am expecting you to report positive results!
It feels like changing a flat tire.Based on the condition of your factory impellers I am expecting you to report positive results!
When you do a side-by-side comparison of port and strbd, looking at lateral profiles, I'm curious if you can see the pitch differences on the trailing edges. It could be very small, like 1mm, but you should be able to easily tell if you rotate it on a smooth surface up against a ruler.Another picView attachment 45398
