New Speakers
dexx00420
Yakima, WA
I've searched on this forum but haven't found any similar comments in regards to my situation. I purchased some MB Quart 6.5's to replace my stock speakers in my AR190. Went to install them today and although everything matches up, the speakers still do not fit; seems like the back side of the speaker is too wide.
Is this the problem I'll have to deal with on any replacement speaker or am I just lucky with these particular ones? I'm not prepared to go nuts with a dremel and would just prefer to swap one speaker for another with no adjustments needed.
Any advice / help would be greatly appreciated!
Thanks,
swatski
North Caldwell, NJ
Thanks,
@dexx00420 All I know is Polk DB651 are a drop-in replacement, they were an easy fit in my 190, so if your new MB Quart's are not MUCH bigger - it should not be an issue.
Here are Polk dimensions:
upload_2016-3-26_23-41-12.pngupload_2016-3-26_23-41-33.pngupload_2016-3-26_23-41-52.png
dexx00420
Yakima, WA
Thanks Swatski! Maybe I'll just send mine back and get the Polks.
KyleWade14
Washington, OK
My JL MX650s fit right in the same hole.
Jwiley
Joplin, Missouri
i just purchased a '14 SX190! Pretty pumped up! @swatski... were the Polk's a huge improvement over your stock speakers? (without amp) I am a huge Polk fan, in fact they are in my basement as well as my truck. I am curious if they are big improvement over stock without adding more power. Thanks
@dexx00420, did you install the MB's or swap them for the Polks?
octavio3311
Brookfield, Ct
@Jwiley - I assume your boat came stock with those cheap ass Seaworthy speakers. If so, any speaker you put in there will be an improvement. The Polks will be a considerable upgrade. Putting a amp to them would make for a HUGE improvement.
dexx00420
Yakima, WA
I ended up sending the MB's back and have the Polks in the mail; with the reputation the Polks have plus not having to make the cutout any bigger was an easy decision. Probably going to add an amp in a couple months but I think just getting rid of the stock speakers will be nice.
Jwiley
Joplin, Missouri
@octavio3311 you would be correct. When i added the DB series in my truck they didn't sound good until i put power to them. I was curious if they would sound better than the factory without adding additional power.
swatski
North Caldwell, NJ
This is EXACTLY how I would describe it, too.
In my case, I decided to leave the stock HU, which in my boat is the infamous JBL M145.2. That thing would drive me crazy - cutting out and randomly interrupting, exactly how others described it. Should have chucked it, but I'm kind of stubborn and decided to try to fix it first... Well, it turned out to be the main plug issue - had some contacts wiggle loose. I could not fix it, so I ended up cutting it off and nicely soldering and heat shrinking all line outputs to speaker lines - problem solved.
It was a relief. So then I cut them again and remounted everything with a new amp I added. I still have that stereo HU. It is actually fine with the amps.
Racerx805
I got the Polk DB651 but had to drill new mounting holes as the stock speaker mounts were a different diameter.
Wr3ckdiver
Homestead, Florida
I have an Alpine deck that I want to use to replace the crap stock unit, any issues with using a regular car stereo vs. a marine unit? The deck use to be in my Tundra that I traded in for a new one so I want to reuse it. Since its in the glovebox I think it should stay dry. Wondering how amazing it will sound with these Polk speakers.
robert843
Myrtle Beach, SC
Honestly they may sound a little cleaner at higher volumes then your stock speakers but with no additional power the overal volume will likely be about exactly the same. Unless your stock speakers are blown you probably won't notice to much difference with out adding an amp.
Polks over the Seaworthy speakers are like night and day! Try replacing just one side and fade back and forth between them! When I did this, I made my wife come out and listen. This began with the usual .... :rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes: from her (Fine...I'm come listen to your stereo....)
For once, when I faded back and forth she was like :winkingthumbsup":):):) and said..."Wow...thats a major difference".
So if your wife is like mine....do that. Otherwise, when you swap them out and play them, they won't tell the difference, but the side by side demo sells them totally!
Wr3ckdiver
Homestead, Florida
The Alpine deck I had in my truck made a world of difference even with stock Toyota speakers, so I am sure it will sound awesome even without an amp.
