One picture of your last outing.
No, i didn’t know anything about that until I came here afterwards looking for Info on the best way to get the rope out. Of course that led to replacing the impeller bearings, found the grooves on the starboard side drive shaft, then I pulled the sparks plugs and made sure no water made it that far up.
Since then I have found I can’t get either of the clean out plugs to come out and the starboard side motor will not crank. It will turn over fine but will not fire off.
You can tie a rope the the plug handle, attach it to a car Jack and lift the plugs out. I use a board to put across the clean out plug opening and put the Jack on top of that. It could be your impellers are stuck and not allowing the motor to completely turn over.
Not really my last outing, just got in the custom gatorstep for the RTIC 65 cooler and next outing ?
sweet topper...where from?
where does that big boy go on the new boat? guessing on floor and use as an island footrest?
Got it from gatorstep. Fits on top of engine access with sliding seat moved up one notch- heres the old blue cooler in the spot
Not another boat in sight for miles at Lake Oahe
Saturday on Lake Partridge in Fremont with @Brad460 and his crew……
Grabbed a bite at the Bridge Bar……
Kitty Corona playing at Skippers in Fremont - we only caught about 5-6 songs but they were really good……
Spent the evening at the River Deck in downtown Fremont with @drewkaree and his crew……
We’ve been up to Fremont twice over the past two summers and it is an absolute blast.
