Liquor&Guessing
- Pittsboro, NC
- 242X E-Series
I'm new to jet boats and and the forum and just recently wrapped my first ski rope around the impeller shaft. Great experience that was.
Some background. After limping home on one engine at 8mph or less i finally make it back to the ramp. I cut off all the rope I could then realized I would have to remove the jet pump to get the rest. Several forum members were very helpful to me with that process. I removed and reinstalled the jet pump as all looked ok then tested the starboard engine (this is the one that had the rope around the shaft) with a hose in the driveway and it now seems to have a metallic, rattling sound to it. I tested the port side engine the same way and very smooth with no metallic rattling sound. The boat is fairly new to me and haven't noticed it before but honestly could have already been there. The rattling only happens at low idle. Once I apply on a small amount of throttle it quiets down. Boat has 130 hours.
It was hard to tell if the noise was from the engine or the pump but seemed to me it was more in the impeller area. Any thoughts or feedback is appreciated.
Planning a lake run to further assess the noise to see if it's still there under more load.
