If I were wet slipping, I would wire in a secondary bilge pump with a manual float switch and wire directly to the battery bank. This way, the boat can remain in the water with the battery switch off and no battery power will be lost to led lights in the bilge switch and random pump cycling. Increasing your battery bank is advised if you cant run the boat on continuous shore power/battery charger.
Totally, with a fuse close to the bat.
Here is a quick repost of
my setup:
"I don't particularly care for the factory bilge pump set up. I don't really like leaving the boat with battery switches on, if it can be avoided.... So, in my boat I finally got a backup bilge pump installed - the way I like it - direct to the battery (fused).
I use the simplest of all pumps - an automatic with a float switch. Attwood or Rule, doesn't matter, they are all the same. They all get terrible reviews, but I think it is primarily due to installation and maintenance issues.
The Ultra (brand) switch is about the only thing that will not fail - and something I would get if I wet slipped.
Otherwise, they all
can get stuck in either "off" or "on" position, but I believe those inexpensive float switch automatics are actuslly the most reliable, if frequently tested and kept reasonably clean. One of my past boats leaked heavily (before I rebuilt the transom) - I had a chance to test various setups over the few years I kept it, lol.
Basically - the cycling ones (like the OEM pump) sense a load, any load - so it could be debris that will keep those on and drain your battery pretty quickly leaving the boat unprotected. Same with the "actual liquid sensing" (conductance, optical or whatever) - those can be fooled/activated by dirt - and stay "on". What is even more worrisome, neither of those two types (or the newer ones that "sense" but then default to "cycling" if they think it is just dirt) will actually pump if gasoline or oil is present...
(I'm all for clean environment, but if my boat sinks....)
Here is my backup bilge pump setup (inside the stern):
The pump's base is screwed and 5200-ed to one of the support beams (for the ride plate underneath the hull) at the bottom of the bilge.
This backup pump operates completely independently of the factory bilge pump and is the only device in my boat that is live when all battery switches are "OFF". I have it wired directly to the house battery with a 16awg wire (using ground-black, and automatic - brown, with the brown/white - manual sealed off) running in a loom (top in the picture) - going into the engine compartment inside another large loom, along steering cables. The hot wire is fused within few inches of the positive terminal with a 5A fuse. The drain hose (bottom) is a standard 5ft 3/4" with a dedicated thru-hull outlet fitting installed above/forward off of the strbd rear cleat (don't have a picture).
Oh, I forgot to add - the pump is accessible through the cleanout tray hatch/opening - I can reach it to test the pump with the little dial knob. "
EDIT: Here is a picture of the outlet - the pump ejects a 5ft long stream. When putting this kind of back up together - I think it is very important to have an independent hose line/outlet, a well designed system with a short, clear path is more important than the nominal "GPH" rating of a pump, which is often based on unrealistic circumstances.
