Justin2121
- Scarab
- HO Impulse
Hi all,
So it's a long story, but I'd like to figure out what happened, if I did something wrong or should have done something.
Yesterday I was out for a day of boating with a bunch friends, took a couple people out tubing then went for two 30+ minute boat rides around the lake, no issues, went out for one last ride and as I was heading full speed back to the cottage the boat sputtered and died, the bilge started pissing out water, we were completely stopped, level and floating in the water, boat wouldn't start. I looked in the ski locker and it was beginning to fill with water, side compartments and engine bay as well (obviously that's what stopped the engine). The ski compartment had filled with hot water before (it was lake temp. water this time) so I wasn't worried, previous time we just turned on the bilge and we were good to go, this time however, that didn't happen. Ski compartment completely filled with water and started flooding into the boat, water started bubbling in from the drains at the rear seating area, it was clear that we were slowly sinking. We managed to get towed back to shore and a good 6 inches of water was in the passenger seating area, put it on the lift to check the hull, we hadn't hit anything, no holes and whatnot, the plugs were still in the back of the boat, as soon as the engine compartment drained the boat fired back up... Seemingly nothing wrong, the boat just wanted to be a submarine.
Has anybody else had this problem before? What would cause the boat to take on water? Why would the boat take on enough water in the engine compartment to snuff out the engine?
We've brainstormed and can't think of a reasonable explanation, any theory is welcome.
Thanks in advance!
Thanks in advance!
