flyingnugget
- Newnan, GA
- 255XD
That was hysterical…
it was definitely brisk today
Seasons are changing! Send some cool down here, please!!
That is perfection! A little too chilly at night but I can throw an extra blanket on.
Looks like a Starlink train in the sky.
This strikes me as a safety hazard, so I feel compelled to comment. If you have properly engineered the system then please disregard and carry on.New addition to my shop, made a custom x and y axis trolly system with a 1400lb winch.
It has 5 square feet of travel. Came up with this for jetboat engines mostly because cant use my lift arms for boats
View attachment 226468View attachment 226469
The max weight this winch will be lifting is under 300 lbs. The average jetski engine without the intake and exhaust is 150lbs so add an aluminum exhaust and intake and it might be 200. So Mister Engineer i know the load capacity of every piece of hardware used to build this. I dont do anything without proper research. You obviously dont know who i am and my qualifications.This strikes me as a safety hazard, so I feel compelled to comment. If you have properly engineered the system then please disregard and carry on.
It's hard to tell from the photos, but this looks like basic P1000 Unistrut or equivalent. If that is true, then you have created a system where the 1,400 lb winch capacity can significantly overload the Unistrut support. I'd be happy to elaborate if you have questions.
Source: Professional Engineer in the design of overhead cranes and hoists.
Are you sure about the weight of the engine? I think the 1.8L engine I’ve got on a dolly downstairs weighs a lot more than 150 lbs but wouldn’t have any issue trying to lift it with your rig given the other feedback I’d be hesitant to use that rig to lift a ski to move it from a dolly to a trailer or vise versa. As I recall, the current fx and gp Waverunners weight between 800 and 900 lbs dry.The max weight this winch will be lifting is under 300 lbs. The average jetski engine without the intake and exhaust is 150lbs so add an aluminum exhaust and intake and it might be 200. So Mister Engineer i know the load capacity of every piece of hardware used to build this. I dont do anything without proper research. You obviously dont know who i am and my qualifications.
And no i do not need any advice from a person like you
Once again i did not say i was lifting a ski off a trailer or dolly. I have a 10klb lift for that. Yes a stripped 1.8 engine without the exhaust and intake is aprox 150lbs. So yes with everything on them is still under 300lbs.Are you sure about the weight of the engine? I think the 1.8L engine I’ve got on a dolly downstairs weighs a lot more than 150 lbs but wouldn’t have any issue trying to lift it with your rig but given the other feedback I’d be hesitant to use that rig to lift a ski to move it from a dolly to a trailer or vise versa.
@YamaHOO did not deserve such a snarky response. He clearly stated that he is only chiming in because he thinks there maybe a safety issue.
