Simrad Depthfinder Inop
AlpharettaRK
Today the depthfinder did not work in my factory 9” Simrad. The temp was shown but not the depth and all the fish I didn’t catch were not displayed . I power cycled house power a couple times and unplugged and reconnected the wires on the back of the unit to no avail. The gps chart works fine. If it’s a clue I was unable to change frequency from 200mhz, that was greyed out. Anything simple to try before calling dealer? TIA
Cheers
Randy
NeverAgain3
Port St Lucie, FL
Had the same. Found this. Boat is breaking faster than I can fix it.
Tranquility Base
Go into the settings and see if the Simrad sees the transducer.
Do you check to see if there was any debris on the transducer? Did you visually check the transducer?
Tranquility Base
AlpharettaRK
@FSH 210 Sport thanks for the reply. Where Is transducer? I assumed it was thru-hull so I didn’t look. Boat is on lift so it wouldn’t be hard. I went thru all the menus I didn’t see a settings menu about transducer
thanks.
Tranquility Base
thanks.
Its either in the engine bay or the aft bilge. Somewhere in the settings or other menu there should be description of the transducer and at least I my Solix there is some sort of a connectivity status.
AlpharettaRK
Thanks. I couldn’t find anything amiss. My dealer has a shop in my marina they are going hook transducer up to test scanner this week in my slip and see if it’s bad. I’ll post whenever it’s diagnosed.
cheers
