Solar Powered Cargo Trailer
Zackdadams
MS Gulf Coast
Thought some of you might be interested in this.
I've been running solar systems in my trailers for years, and recently purchased a new rig for my electrical business.
It's a 7x14x7 trailer, with Polycore walls, electric braking system, mag wheels, side vents, 2-5/16" ball, and more.
Truck pictured: 2021 Ram 1500 Limited Night Edition w/Etorque/Air Suspension
This is my mobile Electrical and Technology Workshop.
The new setup is a completely off-grid contractor setup I've designed.
I do not carry a generator, and am able to run all my equipment from the solar array.
This includes hammer drills, chop saws, battery chargers, etc.
I also carry a small 700watt microwave on-board for lunch time.
I've installed motion activated LED lights on the interior, and of course surveillance.
The system is expandable with more batteries if I ever see a need.
And yes, I'm definitely Team Red.
The system is all Renogy:
  • 4x 100watt Panels on the roof
  • 30Amp Charge Controller
  • 200AH 12V AGM Battery in NOCO Enclosure
  • 3000watt Pure Sine Wave Inverter
  • Battery Monitor & Bluetooth Module
In full sun, I have almost infinite power, producing a 20amp+ charge to my battery.
Here are some pictures.
fatboyroy
Sebastian, FL
I have same setup in my travel trailer 400watts renogy on roof, I can camp out as long as l want and I can run tv, refrigerator and lights all night with 400Ah golf cart batteries but not AC though
FSH 210 Sport
Tranquility Base
What an awesome job Zack!
Zackdadams
MS Gulf Coast
That's really cool, I thought about adding a mini fridge.
From my calculations I could run a small mini fridge for 4 days on this 200AH battery, if there were no sun.
Plus I know my OCD self, I most likely going to add another 200AH battery!
This 3000watt inverter needs 300AH in batteries to run properly, according to Renogy.
I need to test my pvc pipe heater on this system and see if it will run it, it pulls 2500watts!
fatboyroy
Sebastian, FL
I only have 2000watt pure sine wave inverter but yes you can definitely run small fridge, you can even choose a 12v mini fridge so no need for inverter.
HangOutdoors
Royal Oak, MI
Awesome setup.
Forgive my ignorance, but how do solar panels work when it is cloudy/overcast? Do they work at all or does it it have to be direct sunlight?
