Super Mable Fill Valves in wrong place
Beepete1
Chaparral
Wake
Please help!
We bought a Super Mable and all of the valves(except one) are under the bladder and nearly impossible to reach. This makes completely inflating it impossible. Can anyone out there give us some help? Thanks you!
I had a tube that did that once, it was because the cover was twisted and needed moving. Took 3 people to fix it...we partially inflated it, then spent some time shifting the cover around on the partially inflated bladder.
If you've tried this, then the only option would be to call the manufacturer and get a replacement.....
AndyD
Wake Forest, NC
I don't have the super mable but I have a similar version from another manufacturer that does the same thing. On mine, there is a large zipper on the back of the cover to help water drain from between the air chambers and the cover itself. I had to open the zipper and pull the largest air chamber completely out of the cover and it then allowed me to gain access to some acces pojnts inside to twist and move the other chambers around inside the cover and get them lined up and straight. Not sure if you're able to do the same.
