dels
- Jacksonville, FL
- FSH Sport
Installed my 2021 Thrust Vectors this pm!! Cant wait to try em out.
What are you looking for on the timing chain inspection? I might need to do that this year on my ar192Pulled the valve covers to do the pre-season timing chain inspection and installed the ridesteady.View attachment 141780View attachment 141781
Nice! I see you are in the Orlando area. I'm hoping to get my boat in March/April, so I will reach out to you then for the registration #'s and boat name design.I do full print not cut vynil
Finally got to take out the boat yesterday, last outing Dec. 10th. Started cold, 35 degrees, warmed up to 45 noon time and high 50s late afternoon . Finally got to the 10 hour mark (10.9).
So today brought the boat home from storage unit and started the 10 hour service. From day one, the oil level was past the high mark. After leveling engine, not the boat, After leveling engine, not boat, hooked up water hose, started engine then water. Ran for six minutes varying RPMs and checked that thermostat had opened, turned water Off, then engine. Set five minutes and checked oil level, still past high mark.
Removed 3.4 quarts plus what was left in oil filter. Cleaned up, installed filter added 3.25 quarts of oil. Ran engine and water for five minutes and stopped. After removing water hose and bring everything else off the boat rechecked the oil level..Was in the middle of both dots/holes. I did remove the air filter to check out, was very clean, no spotting or debris on it. Reinstalled.
I was going to add a squirt of grease into the bearing housing but did not.
I have included a picture of how the bearing housing cert is rigged up and need clarification from you pros out there. Their is a house zip tied to the nipple and runs up to the back of the engine. Is it dummied or what.View attachment 140414View attachment 140415
Today I finally spoke with the service manager at PhilDill boats Lewisville Texas on the bearing.
Turns out for this model 2021 195FSH CC Sport it has a new unserviceable lifetime bearing that is to be left alone.
So for me as long as I own this boat I will leave it alone and yes I documented on my service manual.
I Have 2, 2021 intermediate bearings on my new skies I have no doubt that your bearing also has the grease fitting and I have no doubt that The bearings do not need grease I removed the grease fittings and attached some other hose barb fittings with some tubing to allow me acces to the housing using the syringe and gear lube that I have been advising people to use rather than pumping any grease in and damaging the seals or rubber. I did that before I ever launched them.Today I finally spoke with the service manager at PhilDill boats Lewisville Texas on the bearing.
Yes, my manual states to add grease at 10 hours and there after at 100 hours that’s why I contacted dealer because I didn’t want to undo something I wasn’t familiar with.
The pictures are on the reply as attachment 140415 above. Click on click to expand.
JD-84 2004877 is what the label states that is stamped on it.
Just a point of clarification on this subject after seeing Jeff's post. It is true that the "bearing" itself contained within the housing is sealed and "doesn't" require greasing thru the Zerk fitting. What you are actually adding grease to are the seals in front and behind the bearings. That is what prevents water intrusion, the seals. So yes, they should be greased to prevent seal failure. What I would like to see is if there is a part # change for the 2021 boats. Depending on what changed, if anything, then we can see if its true. I honestly doubt it because this same design has been around since at least the 90's. My 95 Raider has the same design on it.
OK, so Raider has the same design, how has Raider approached this issue? I want to know.
