The thing that charges our batteries on the engine
Nous Defions
I have read some where that: Each engine on the 240 has a rectifier regulator that limits maximum output voltage to 13 volts between 2000-3500 rpm's, with a stator coil output voltage of 8.3v cranking, 36.4v@2000rpm, and 64.7v@3500rpm.
Another site says there are 40 amp magnetos on each engine.
If it's correct that each engine has a 40 Amp charging system does that mean the total amps possible for a charge is 80 amps?
Any electrical guru's out there that can clarify volts vs. amps vs total?
Beachbummer
Houston TX
I was interested in your question and found even more questions in terms of how relevant this information really is to reach a full charge, due to battery's limited absorption rates
Regardless of the answer, it appears much less relevant than I thought.
Check this out if you have some extra time.
Nous Defions
How can I use this information to work for me?
Beachbummer
Houston TX
Beware that it takes time vs current to refill from below 50%.
Figure 15-8 amp Max charge rate, diminishing the higher charge it has, and compare to expected run time.
Nous Defions
Let me try asking my question a different way. If there are two magnetos with a max charge ability 40 amps each, does that equal a possible 80 amps max? Asking for fusing requirement.
Beachbummer
Houston TX
Where is the fuse going? Should you not be concerned with the max draw from the starter while cranking for fusing requirements too? or are you fusing the voltage regulator only?
Nous Defions
The long story is I contacted Blue Sea Systems because this wiring looked different from the instructions provided. The Blue Sea rep sent this back with where he suggests fuses without provided what size. With 4 gauge wire and a charging system of what I believe could be 80 Amps, trying to figure what size fuse is appropriate.
Beachbummer
Houston TX
Your fuse should support all possible loads (except for starting, since the ACR is not supposed to be active when starting the boat) What's the rating on the ACR? That should be the switch size.
There is a Minimum charging AMP advertised as 23.3-25.3 in a similar engine to yours for the 2008 FX SHO waverunner. If you want to add a fuse, I would suggest a fuse with the rating of the ACR. (Likely 60 or 80 amps? check the ACR and any instructions it came with)
Mainah
Chapin, SC
@Mainah did you ever dig into this?
I have never found firm numbers on stator output or tested it myself. 40a each @13.1v seems awful high to me even at WOT. As to the question of fuse ...You should fuse for wire capacity in most cases. In some case you fuse for the weakest link/component in the circuit. I would fuse at or below rated capacity of the wire, fuse, or ACR (whichever is the least) on the load side(s).
AGMs have great absorption and discharge rates. Lifepo4 easily beats AGM but that is a different conversation given the complexities with Lifepo4. I did figure out that running my two g31 AGM as a single bank (combine on) for discharge really helps split the large load I put on them and I get less voltage drop when running three ballast pumps at the same time.
Beachbummer
Houston TX
Also, Note that in most cases the cables going to the master switch are not fused. I wonder why something like this, or a large breaker of similar rating is not standard.
Nous Defions
Reading Blue Sea Wire & Fuse Size Chart, I should be using a 100-125A fuse if I read the chart right. Charging Amps:80, Wire Size:4.
What I don't want is to be tooling along and blowing fuses because I went too small nor tooling along and having a melt down because I went to big.
Do I trust the instructions and call it a day or am I over thinking this?
biglar155
Fredonia, WI
Use the chart. Fuses should be sized to protect the current carrying conductor. The load you expect to carry determines wire size and wire size determines fuse size.
Nous Defions
So now the big question goes back to 100 Amp or 125 Amp fuse? Why do they give a range? Now I have to also carry two $16 fuses just in case they blow.
Beachbummer
Houston TX
I think you answered your own question in terms of priority (and I agree with your logic) You are given a range and you prefer it not to blow. The larger fuse will be closer to accomplishing your goals...
And, Why let it blow? Get the breaker that can be reset, so you are not stranded by needing fuse spares.
Nous Defions
Reading reviews on the circuit breaker (cheap) not willing to chance it. Thinking of being out in the middle of no where and thinking glad I saved $20. I'll spend the bucks and get the fuses!
Thanks for the back and forth, I appreciate it.
Speedling
Cedar Lake, IN
SS
This may help with not needing to carry extra fuses.
I started using these on my amps a few years ago. Work great! Know stuff is off without draining overnight too
Nous Defions
Reading the reviews, some say cheap and after blowing a few times will not work anymore. Also blow very easy like not up to the rating. Also can't find one rated at 125A.
biglar155
Fredonia, WI
Just to be clear: That fuse you showed is called a Terminal Fuse and requires a special fuse-holder. You can't just drop that over a battery terminal. You have to have this:
Not sayin' you didn't know. Just making sure everyone knows. Amateur electricians burn a lot of things down every year. It's the reason the Electrical Codes exist. ;)
