Tool Kit
Mark Hoell
Does Yamaha make a tool kit that contains everything you'd need to do minor repairs while on the water? I don't want to buy an 30 piece socket set if only 5 of them can be used. Maybe it has screwdrivers and only sockets needed, pliers, VOM etc..
Interesting idea for @JetBoatPilot
Yamaha doesn't make one.
tdonoughue
The Woodlands, TX 77381
(if they did, they would probably charge $250 for the $50 of tools they would put in)
I took a cheap tool box from the garage and loaded it with all my tool 2nds i had lying around. That 2nd Phillips head screwdriver, the 2nd straight blade, the 2nd set of hex keys, pliers, etc. I think the only thing I did wind up getting was a socket set and a set of ratchet crescent wrenches. All in all I think I spent $40.
mattster
Carmel, IN
Limited
And don't forget a sharp knife that can cut a ski rope...just in case. And a pliers that can extract a twig from a tight spot. And an LED light, so you can see down a 2' black hole in the event something gets stuck down there.
Troy JK
other stuff I added. some extra hose clamps, ty-wraps, 16” needle nose pliers, long knife, electrical crimp connectors and fuses. 👍
FLBulldogger
I bought this TOOLKIT from harbor freight and put it in the boat it's flat and has just about everything you may need. I do have an additional tool box with zip ties, hose clamp for towing, fuses, gloves, sharp knife, etc that I keep with our emergency supplies.
anmut
212S
Cheap metric socket set, allen key set, knife, carpet cutter, long needle nose, batteries, flashlight, extra ratchet straps, screwdriver with changeable shaft, wrench, all in a Plano toolbox that fits in the battery seat storage compartment, slid all the way to the rear.
