Trevor Shipman
- Charlotte, NC
Hey guys, have a trailer question.
I have the original trailer with surge brakes that came with our 2006 AR210. The rear wheels with the brakes are running extreamely hot (both sides of the trailer). So hot that it's spewing grease everywhere. I took a look to see what it could be, I jacked it up and the tire takes a little bit of effort to move (rotate). The surge on the hitch is completely released and there still seems to be tension on the rotor. I'm thinking the caliper is not releasing fully once the brake is applied.
With that said, I also have one broken lug so I was just going to order the whole thing but I'm not sure if I'm ordering the right assembly. We are going on a trip this weekend so I want to make sure I order the right setup so I have time to install before our trip. Thanks for all the help.
KODIAK 10" Trailer Disc Brake Assy, DAC Bearings & Seals incl. (Comp. 1 Axle Kit) https://www.amazon.com/dp/B006UH5IMC/ref=cm_sw_r_cp_api_7akBzbHVCM2RT
