What is this thing?
Tower bracket.
if you fold the tower down, you’ll use that to go between the boat and the rear leg of the tower to hold it secure when folded.
You should have 3 bars. 2 for the tower legs and the 3rd goes on the bimini
I'm glad I saw the post and thanks for your answer. I had the same question since I purchased mine used and had the bars in one of the storage areas.
Actually, I only have 2 flat bars and not the third bar with the big head. Not sure if I need that or not.
Looks like you have 2 bars on the front. Is that right? I suspect that changed in ‘18, when the tower changed.
Yup...one bar on each side. You can see each bar in this image:
dscn1870-jpg.38067
Didi you have any luck when you called Chattel getting them as I didn't know about them either and need to call them
