Want To Buy WTB yamaha 230 or 232 Ski Locker floor hatch
35tsc
Looking for a replacement hatch door for the ski locker as mine is weak and needs replaced. Let me know if someone has one or knows of a boat being parted out. I think any 230 model 2007 and new will work.
Yamaha OEM number
Hatch, Floor
F2A-U5111-00-P0
Thanks in advance
I wonder if a new latch would fit in the same hole? I assume you are seeking part outs because you can't find the OEM latch anywhere?
Have you considered trying to fix it?
I'm guessing it's rotting from a loose latch fitting ?? If so I had good luck rehabbing my cleanout hatch cover from rot,
check out the link in my sig. below for some good info on your boat,
I did try to rehab but failed at first attempt. I need to do it over the winter when I have more time. In the meantime - I thought it would be easier to just buy a new door someone had around.
Thanks
