LukaszZelias
- Poland
Hello
I am from Poland and I am the first owner of a yamaha ar230 boat.
I found this forum because I have a problem with one engine
I released the boat last weekend and found that I had a problem with the battery. I started the boat with a second battery, both engines were working. after a few seconds one engine reached high speed and went out.
I checked:
Spark plugs, I moved to a second engine, which is equipped with it
coils, I switched to a second engine that is coming and it's okay
the fuel pump creates pressure (after removing the hose that goes to the engine, it spurts fuel)
I switched computers, switched to a second engine that works and is fine
pulling (leash) I connected the cables, bypassing the button
fuses are good
I use a translator, so sorry for the mistakes
Please help
I checked:
fuses are good
Please help
