242x revs but will not move forward
runmike44
My 2016 242x was working fine for about 10 minutes. I slowed down, then tried to move forward again. The starboard engine would rev up but would not move forward or reverse. I turned off the starboard engine and then turned it on a couple of times but it did not correct the issue. Fortunately, the port engine was working in both forward and reverse and got us back to the dock. Back at storage, I inspected the gates visually and everything appeared ok. Any ideas what I need to check and/or replace?
Babin Farms
Lower Alabama
Something covering the intake?? Clean out plug seated?
Cobra Jet Steering LLC
Vendor
Florida
parking brake is on !!!
Cambo
Long Island
On the way back the blockage could have flushed out. It doesn't take much to make the jet thrust cavitate a few pieces of eel grass or other debri can throw off the efficiency of the thrust. How does the impeller look and feel are the edges smooth?
runmike44
I went back to storage and started the motors. The gates both reacted identically in neutral, forward, and reverse. The impellers look ok. Just hesitant to go back on the water only to have same problem. Guess that's the only way to see if all is ok, huh? If anyone has any ideas on what to check before going back on the water (besides shooting the sob), I'd appreciate hearing them.
Judge
Cape Coral, FL
275SD
If the buckets are moving up and down normally, the clean-out plug is sealed and there is no visual signs of debris at the grate or impeller, it has to produce thrust if the shaft and impeller are intact.
As others said, the blockage may have cleared on the way back into shore but a classic sign of a blockage is no thrust.
sunbyrned
Louisville, KY
These things have been mentioned already but I’ll reiterate. Make sure the clean-out port covers are secure. I would also pull the pump to check for debris. Even if you don’t find anything, sometimes just pulling the impeller out and reinserting it does the trick. Easy process. Here’s how to do it.
sunbyrned
Louisville, KY
One more thing to consider checking since you made it back on one motor. If you didn’t clamp the water line, you could have gotten water in the engine. Maybe check the color of your oil in starboard engine.
Judge
Cape Coral, FL
275SD
Great video! That stick would have been hard to see from under the boat.
runmike44
Will do. Thanks for info.
