Member map not working on iPad
Bruce
Royal, AR
@AndyB, there is some interesting feedback on the members map in this thread.
2kwik4u
Georgetown, IN
I just checked and can't find myself on the map. Not sure which city I was traveling in when it grabbed my IP, but it certainly wasn't my home town.
Can I opt out of the map?
Bruce
Royal, AR
Looking at the database data it should show me at 32.6255, -97.0784 which it does. That is south of Dallas / Fort Worth in an area that I have not visited in over a year.
The database shows you in Columbus which is also shown on the map.
Both of us are in clusters which I assume have come from the geolocation of mobile data IPs.
I could create a user group that opted out of geolocation. I am hopeful that can be implemented on an individual user basis.
I believe that it would be better to use the declared location for users who provide it.
The map updates are monthly so they are not revealing your location or showing your travel in real time.
2kwik4u
Georgetown, IN
I haven't been in Columbus in over a year. That's wierd.
How did you find me on the map? It's there a search?
Keep us posted on the opt out group.
Thanks for the help!
Bruce
Royal, AR
The map does not have any way to search for users. I searched the database that is used to generate the map.
That data does not include the IP that was goelocated. Geolocation data often is poor for mobile data. The IPs are registered to a central location and passed out based on need. You and I likely were using mobile IPs that mapped to DFW and Columbus right before the update.
@Bruce are we running the DragonByte member map? The addons list suggests we are not....
It still has me in the Bahamas....I wish! LOL
Would be so much better if it would go by your stated location first, then by your IP if you don't have one. Then all we'd need to do is tell anyone who doesn't want their location shown to just put their State in their location, then they'd be anonymous.
Bruce
Royal, AR
I switched to the XF2Addons map which is much more functional. The developer should be seeing this thread.
zipper
Boston Whaler
I don't exist on the map anymore.
Scottintexas
Corinth, TX (DFW)
just FYI,
I just checked and Betik, Txav8r and myself are not listed on the map (at least where we should be)
The new map determines your location based on your IP address - so where you provider is located. This isn't always optimal....and if you use a VPN, can put you way off in who knows where! It also has some sort of time cutoff and only displays "active" members, and refreshes on a limited timeframe. @Bruce can perhaps illuminate us on what he learned when he dug into it....
There is an update (V1.4) that would allow us to chose the "active days"....we'll update to that at some point....
Bruce
Royal, AR
@Julian, I believe the active days feature would reduce the number of members displayed to those that had been recently active.
I agree that this map is not as good as it could be but it is the best of what is currently available. I discussed our issues with the developer and pointed him to this thread. Unfortunately our members and the developer disagree about the optimal function of the member map.
Does the current version not have some built in/hard coded activity cut off? Clearly it isn't mapping everyone all the time (as an example, I looked up where Zipper logged in from, and his IP would have put him close to Burlington VT-where he lives, but he's nowhere to be seen).
Pity the developer wouldn't put in the option to map off the profile location first, then IP location if no profile location exists. That would allow people to be anonymous if they wanted to (by entering "Antarctica" for example).
zipper
Boston Whaler
I agree...based on the map, I have gone off the radar. I am not listed in Vermont or any of these pins in the screenshot...And I can see Burlington from my house. ;)
Just above in post #6 I was good, in post #14 it put me in Enosburg. Now I am not to be found.
Scottintexas
Corinth, TX (DFW)
just an fyi,
The map does seem to be loading much faster now but,,,
The window that pops up to show the member name is now blank, it will expand the window like there are multiple members in the spot but no names are listed,
pretty sure this worked properly last week or two ago,
Scottintexas
Corinth, TX (DFW)
I was working on my windows computer but also the android phone displays the same,
Are you using the new dark format?
I just tested with Dark style, and it APPEARS blank, but in actuality, the text is there just in light yellow font. If you point at it with a mouse it shows you the names.....
Not sure how easy that will be to fix in the style.... going to check with the style author to see....
Scottintexas
Corinth, TX (DFW)
You are correct, I was using the dark format and the names did show up once I scrolled over the pop up window,
just another fyi, I'm still not showing up on the map (at least where I should be)
I know this is work in progress and the map has issues, just letting somebody know,
zipper
Boston Whaler
You are correct... I'm still not showing up on the map (at least where I should be)
Ditto. Not on the Map.
The new map uses your IP address as your location. So you may not show up where you actually live. Also, it seems really random as to when it decides to put you on the map.
Unfortunately the old map addon is no longer available...so this is all we have. Hopefully someone will write a better map add on soon!
We have upgraded the member map add on. Would users please check to see if it is:
1) Working on the iPad
2) shows them on the map
This is a great utility for us! Thanks to @Bruce and @AndyB for getting this working smothly for us!
