Problems with links in the FAQ?
BigAbe75
Litchfield, IL
The post is still here somewhere. The FAQ is a little wonky right now. Try searching for the keywords and you'll find a bunch of threads. Hopefully, one of them is the right one. :)
@Bruce @Julian @Scottintexas
Lynkage
Axis
Wake
Thanks Abe,
I ended up running across it when scrolling (and scrolling and scrolling) through the FAQ!! :)
Liftr
KY
I can’t get it to display properly on an iPad using Safari. But, it does work on my laptop using Safari.
Lynkage
Axis
Wake
Next time Use the search function described at the top of the page!
I absolutly did use the search function for "Plastic Scupper", "about to fail Scupper", "Scupper failure" and "scupper FAQ 113" and it returned over 200 results each time that did not resemble the results I was hoping for or I missed it in the search results.
If i'm not mistaken, it was your link that led me to search for the answer from a post of yours!
I have tried Edge, Internet Explorer, Chrome and Firefox all with the same results. That is why I posted here. Seemed odd to get the same results from 4 different browsers.
Thanks for the suggestions folks!
Shane
jb32566
Navarre, FL
165 ID
BigAbe75
Litchfield, IL
Shane
That particular issue with the link not going where it was supposed to is not a busted browser. It is a broken permanent link due to the software version upgrade a couple months ago. All browsers will do the same on that issue.
Shane
Are you searching the FAQ using your browser page search? Mine returns 8 for "scupper" search of the FAQ.
Lynkage
Axis
Wake
No unfortunately I did not, I was only using the forum search feature. I had only been a member about 6 hours when searching for this thread. It was one of those times that you can see there is an answer to your question but you can't see the answer. I am now getting familure with the site layout and getting more proficient with finding things. Thanks for your help.
Sorry about the bad links in the FAQ it is something I'll have to look into to see if we can fix! Hope you found what you needed. If not, please ask in a new thread and I am sure we'll be able to get you your answer within minutes.
Lynkage
Axis
Wake
I did find the thread! Parts are ordered and it seemed that the plastic scupper was probably the most important thing to address first!
Thanks again for your help!! 👍
