Trophy Point System Problems <FIXED NOW!>
Bruce
Royal, AR
Thanks to @zipper for noticing that the the point counts had remained inflated.
I believe I have that fixed now.
The forum software only increases the trophy count when a trophy is added or subtracts it when a trophy is removed. So my manual removal of trophies did not remove the associated points. I recalculated all the trophy counts from the database.
Added back the "Reactions" to the post list so you can see which posts have more "Reactions" (likes, agree etc are now called reactions on the forum).
Also corrected all the Trophies associated with Reactions and they should be awarding properly now (also changed the wording to reflect the term "reactions" in all trophies).
Jack Long
Clarksville, TN
I believe mine have been corrected Bruce.
zipper
Boston Whaler
I know this is a trophie point fix thread, and well done by the way...but how is it going on restoring accuracy in the Reaction Score count? No Hurry, just wondering.
Screen shot on 3/27
Ahh, Admiral for a few days.;) And just now, reaction score lower than ratings above.
zipper
Boston Whaler
@Bruce @Julian Wondering if this trophy point software is still working correctly or how long does it usually take. In the past it has been pretty quick, usually within an hour or so. I crossed a threshold yesterday, 4500 positive post reactions and did not see the 10 pts. added. Just curious, am I missing something?
Per the trophy list, all taken this afternoon.
My List of Trophies taken today
Struck me as odd. Not all that important...just wondering if everything is working correctly.
Bruce
Royal, AR
@Julian, I believe that issue is related to Post Ratings versus Reactions.
zipper
Boston Whaler
I guess I don't know the difference...The words "post ratings" at the 4500 threshold is the only one shown with the words "post rating" in the point system. Every other point threshold is called "positive reactions". I am not talking about number of posts. that is a different subject.
Versus this one I am talking about.
Bruce
Royal, AR
@zipper, reactions are now built into Xenforo. Post ratings were a third party add-on that we used before Xenforo added reactions. Previously one of the admins, I think it may have been me updated those trophies to be based on reaction count but missed 4500.
Julian manages those trophies. I never look at them unless someone reports a problem. I corrected the settings for 4500 and you have your ten points now.
zipper
Boston Whaler
Thank you, all is good. I am not trying to create problems, only iron out some of the last wrinkles, as they appear, since the forum upgrade. Again, thanks for the work you do to keep this running smoothly.
zipper
Boston Whaler
What was set wrong? Did I not put the criteria in?
Bruce
Royal, AR
I believe that one of us updated all the post ratings criteria to reactions after the V 2.0 upgrade but missed the trophy for 4,500 reactions.
zipper
Boston Whaler
I believe it was easy to miss, as only this trophy was labeled a "post rating" and not recognized as a "positive reaction" as all the other trophies in that category are called.
Gotcha....the real pain is there is no sort order for the trophies in the admin panel....so I apparently missed it.
zipper
Boston Whaler
Thanks both of you. And thanks for changing the wording to the 4500 pt threshold to be consistant with all the others as "positive reactions".
Dean P
Florida
Chaparral
VRX
Hey guys, @Julian, @Bruce, I think the points are off a little. Could you look into this?
