101 question from a 101 jet boat owner..
Eric Gonzalez
FSH Deluxe
I'm well aware of the "pee" hole you need to keep note of on the side while in the water to make sure your cooling pump is working properly. BUT- Is this the same with flushing it out at the end of the day? I had mine in for the third time and the first was awhile back (don't remember) the second was in fresh water (no need) and the third (yesterday) it was NOT coming out the "pee" hole but was coming out the exhaust..
Is this an issue or normal? Thanks in advance, you guys rock.
haknslash
Lake Martin, AL
Moomba
It takes about 70 psi on the hose to get close to the amount you see coming out at the lake.
Eric Gonzalez
FSH Deluxe
Awesome, just wanted to be sure something wasn't wrong.. thanks again!
adrianp89
Tampa Bay, FL
252SE
Also I have noticed with salt-away it will not pee, but with regular hose it will. Was a concern at first but I quickly realized it is not a big deal.
