Eric Gonzalez
- FSH Deluxe
I'm well aware of the "pee" hole you need to keep note of on the side while in the water to make sure your cooling pump is working properly. BUT- Is this the same with flushing it out at the end of the day? I had mine in for the third time and the first was awhile back (don't remember) the second was in fresh water (no need) and the third (yesterday) it was NOT coming out the "pee" hole but was coming out the exhaust..
Is this an issue or normal? Thanks in advance, you guys rock.
