2015+ Boats Scupper Replacement
afdouble
Upstate, South Carolina
After using the search function and reading most of the "scupper" related posts, I do not see a consensus on whether changing to a stainless steel scupper is warranted on the newer boats (I think 2015 and newer) where the scupper placement is higher , and possibly above the water line.
As such, I thought I would start this post to get the Board's consensus... Have you replaced your 2015+ scupper. If so, Why? What part did you use as a replacement? How did the process go?
OR...Did you decide against it? If so, why?
ALSO..Pros/cons... Deciding too, but waiting? Haven't made a decision yet?
What are the Board's opinions?
Cambo
Long Island
Great question I can’t believe they still use that thing . They did move it up higher mine is just at the water level if it did crack it looks like it could create issues if the water was rough and the boat starts rocking . It’s definitely under water when you slow down and the water washes up on the rear swim deck . The problem is it cracks and you can’t see it that makes it a hard leak to detect
Gym
Falmouth, MA (Cape Cod)
It's likely underwater if you use ballast for watersports. If it's still plastic I'd replace it.
Neutron
New Bern, NC
if its plastic like my 16 ar240, you should replace it regardless. why take a chance
seanmclean
Medford, NJ
I suspect it'll be a few more years whether we know if the 2015+ boats will be an issue. Its on my list of things to do.
Jameson Clark
Laurens, SC
Which one has everyone used to replace the plastic one?
The older boats began having issues because the plastic scupper becomes brittle over time. I suspect this will become an issue for newer boats in a few years if they are using the same thin plastic scupper (I've not studied mine...will next time I open the bilge up!). So my vote is a definite "Maybe"....
afdouble
The older boats began having issues because the plastic scupper becomes brittle over time. I suspect this will become an issue for older boats in a few years if they are using the same thin plastic scupper (I've not studied mine...will next time I open the bilge up!). Do my vote is a definite "Maybe"....
MAYBE...ha, good vote
Cambo
Long Island
It’s the same brand Perko . Its easy to inspect on the newer models you can remove the small inspection hatch in the clean out tray and reach in and move it up and down to see if it’s cracked. They could have been over tightening them on the older models when I replaced mine it was very tight . If siliconed properly it doesn’t need to be torqued much I could not feel any silicone on the inside and the bead on the outside looks light. This could be an area that lets water into the bilge if not installed properly
afdouble
So are you saying the same stainless scupper (Atwood brand I believe) is used to replace the newer boat scuppers also?
Cambo
Long Island
I haven’t changed it on the 242x but I had the old perko scupper from my AR230 and they look identical so the SS Atwood should work.
rkim808
Kauai, Hawaii
I’m definitely changing mines out, after going out with the boat yesterday I noticed it’s bellow the water line at slow speeds and while anchored too. So that being said better safe then sorry, SS Attwood scupper going in.
Aloha,
Rueben
Noko
Lake Nokomis Wis
Is this an issue for 2013, and if so, anyone with a replacement part?
rkim808
Kauai, Hawaii
Rueben,
Please take some pictures and let everyone know your progress. TIA
So I’ll be ordering one in the next couple days, and will be installing as soon as I get it. My thoughts is that is a small expense, but give a great Peace of Mind and Sense of Security.
rkim808
Kauai, Hawaii
Any update Rueben?
Aloha afdouble, no I haven’t gotten it yet. It is on my things to get done ASAP. I call it my ASAP list lol. I know there hasn’t been anybody with late model 21’ or 24’ models that has a scupper valve failure, well none that I’ve found. And that’s a great thing, but I’m sure I would feel much better if I swapped it out. R u planning to do it?
afdouble
Yes, I want to do it for peace of mind. I plan on a May or June install.
