2021 195S Blue Power wire Connection
kgower
Buford, GA
222SE
I have done some searching on the forum but can't seem to find the answer I need. 2021 195S stock Fusion HU (MS-RA70NSX) powering Wet Sound Amps. Where does the blue power wire connect to on the HU to run to the amps? Photo would be great.
The head unit remote power wire is usually blue or blue and white striped.
Thanks Julian. I spoke to Creative Audio who said the same. He indicated that it was the blue wire in the top row. When I told him that it was sealed from the factory with on orange and brown wire, he suggested connecting both blue wire (2 amps) to the larger red wire top row on right of the harness. Your thoughts? Photo attached for reference.
Definitely just Hook to the blue wire on left in pic. Thick red wire is hot. So your amps will constantly be on if you tap into that as well.
I agree, I'd start with the blue wire and see if it works. Then I'd be calling Creative Audio back if it doesn't.
