21 195S won't launch
Phang
195S
Hi all, Well I just change out my impeller and wear ring on my 2021195S and the boat won't accelerate or launch like it use to after the replacement. Before the replacement if I would just WOT at a dead stop the boat would launch up and go but now with the replacement. If I do that it would just rev up like when seaweeds gets stuck in it. I would have to slowly accelerate to about 10 mph to pick up speed then at that point I can slowly accelerate to top speed. I do get up to the same top speed as before. Just can't launch at at dead stop like it use to. Any help would be greatly appreciated! **The impeller and wear ring was replace with OEM**
seanmclean
Medford, NJ
Seems that something didn't go back together correctly. Why did you need to change the impeller and wear ring on such a new boat?
rockinthesuburbs
Saratoga Springs, UT
195S
I think I saw on a different thread that he had sucked up a rock.
Phang
195S
It seems I did put everything back. The big different is that I only hand tight the impeller and didn't torque it.
rockinthesuburbs
195S
Coming from an aircraft mechanic background - I'd say that's probably the problem - and risky! I've seen improperly torqued items that spin at high speeds similar to an impeller in catastrophic failures. The result is never pretty and I've been fortunate enough not to experience any loss of life, however, the damage is usually extensive. I think (hope) that you are implying that you have identified the problem and will take the proper corrective actions?
steveinmd
195S
The impeller is reverse threads and will self tighten. Just needs to be not loose when you reassemble.
Something is causing cavitation. What is out of place inside the pump tunnel?
What is the gap between the impeller and pump housing?
Did you install the correct impeller? I believe the 195 uses a larger diameter impeller than the normally aspirated 1.8s.
How is the caulk in the cracks in the pump tunnel?
Dough
Lake Barkley
Limited
Bet the problem is the silicone in the joints. Has to be perfect.
Phang
195S
This is the impeller I got:
Yamaha - Impeller - 6GN-R1321-10-00
rockinthesuburbs
195S
I see- that makes sense. I digress - my mechanic ocd took over for a minute! One too many failures due to things not being installed correctly.
Maslin
Oregon
Partzilla shows that part number for a list of boats, nothing 19' and nothing newer than 2010.
You sure that's right part?
Edit: yamahapart.com shows it's right, weird.
Phang
195S
Where did you find a place with it in stock?
Order it on partvu.com they had a batch available back in June. I don’t know if they have any available right now.
tdonoughue
The Woodlands, TX 77381
Perhaps a dumb question, but are you sure you reattached the bucket to the cable?
And: pics would help, if you can get them. Side shot of the jet; shot up the intake...
Phang
195S
Have you measured the tolerance between the impeller and the housing? I think the max gap is 3mm. I'm on vacation and don't have easy access to my manual.
I didn’t measure anything. I thought it was plug and play. I will say that when I clean out the port recently I can feel the impeller closer than when it was stock. Like I can just touch it right away as before I have to reach back to touch it. Was I supposed to measure it? And if so how? Thanks
I did attach it. But it was something to look at.
