210 dead rise question
Tailwaters
St Joseph MI
So I see the dead rise at the bow is 20 degrees. Anyone know what the dead rise is at the transom?
Never seen that spec published.....curious why you are interested?
Dead rise is typically measured at the transom (after doing some research)....wouldn't be hard to measure.
2kwik4u
Georgetown, IN
"By the book" the 190/192/195's have a "zero" deadrise at the transom, which is why I think Yamaha only publishes the bow number. I can say without a doubt that even though the deadrise numbers on the two boats are identical (our old vs new), our Yamaha rides 100x smoother than our old Rinker.
I think hull design has changed a lot in recent years, and a "variable deadrise" approach has been taken to many hulls. More at the boat and less at the transom. This would lead to a better cut through waves/wakes, and a higher top speed (or less power required).
Playing - Yamaha AR210 (2011-) - | Yamaha Engine | Powered By BoatTest.com | 524 <--shows the AR210 deadrise/Transom at 20deg.
Jet Ski: 2005 Yamaha AR210 <--That one says 18deg
swatski
North Caldwell, NJ
In a twin inboard jet boat, the intake loading is a major consideration as far as hull design, limiting deadrise, and preventing stepped hull design (that otherwise crept from racing boats into everything, recently).
2kwik4u
Georgetown, IN
Why do you say this? (learning about deadrise a lot today)
The hull is actually "flat" on either side of the pump intake for a few inches. The transom has sort of a \_/ shape to it instead of a \/ shape to it. Clearly it doesn't ride like a flat bottom boat would ride, however it doesn't carry the tip of the "V" all the way from the bow to the transom like a traditional hull would.
*edit* you can see the flat section here:
104936
