"By the book" the 190/192/195's have a "zero" deadrise at the transom, which is why I think Yamaha only publishes the bow number. I can say without a doubt that even though the deadrise numbers on the two boats are identical (our old vs new), our Yamaha rides 100x smoother than our old Rinker.
I think hull design has changed a lot in recent years, and a "variable deadrise" approach has been taken to many hulls. More at the boat and less at the transom. This would lead to a better cut through waves/wakes, and a higher top speed (or less power required).
In a twin inboard jet boat, the intake loading is a major consideration as far as hull design, limiting deadrise, and preventing stepped hull design (that otherwise crept from racing boats into everything, recently).
The hull is actually "flat" on either side of the pump intake for a few inches. The transom has sort of a \_/ shape to it instead of a \/ shape to it. Clearly it doesn't ride like a flat bottom boat would ride, however it doesn't carry the tip of the "V" all the way from the bow to the transom like a traditional hull would.
