Adding Tow Valves, 2004 SX230 questions
Look toward the bottom of the hull in your picture. I believe that is the hose you want to put the valve on.
Not sure how those pictures double posted. The yellow arrow is the direction of cooling water flow from the pump. On my boat these are the ones you would put the valves on.
Ruh roh. Sigh. Guess another eBay purchase is in order... In the engine compartment it sure seems like they're coming out where the cooling line is. I deleted the post so no one makes the same mistake I did. Does anyone know the I.D. of the CORRECT hoses?
MOA_Chaser, my boat and cwoav8r and I have same layout. Please check yours again.
Ha. No problem brother. We got your back. I wish I was in your driveway helping ya.
You'd be here a while, LOL. It takes about 2 weeks for the valves to get here from China. :rolleyes:
I ain't taking it apart tonight though. I'll re-order the valves when I find out what size they are and I'll un-do everything when they get here.
Here is a video that explains the cooling system if your interested.
X2... @MOA_Chaser , sorry man... I was hoping I was wrong, but better to not find out later when you need 'em to work. Give me a sec and I'll see what I can find on the hose...
It's either 1/2" or 5/8"... Bueller... Bueller?
The Island Racing kit for the MR-1's is a 5/8" valve... That jives with the FAQ that @Julian referenced...
OK, reading some more about this and it seems like I don't need to buy new valves. The same supplier has 3/4" * 15mm barbs, which seems to be the I.D. of the PROPER hoses (between 1/2" and 5/8") so I can still use the 3/4" valves, which will give me better flow anyways. He also has a female-female 3/4" collar for $2.55, so I can snag that and put the port side hose back together again.
Thanks guys for catching my screwup... that would have been disastrous if I ever had another engine go down and assumed I was OK to throw the valve and motored in on the remaining engine faster than no-wake! As it is my screwup only cost me about $20 in a set of barbs I don't need.
Sorry, it killed me to post up cause I knew you worked hard at it, and I was not sure if your boat was different...
@Julian do you think it better to resurrect the deleted parts of the thread if possible... just to show folks what happened? If you all think it won't lead to confusion, and with @MOA_Chaser 's approval of course...
Rather than resurrecting that post, how about...
DON'T INSTALL THE VALVES HERE!!!
Ball Valves
Male Barb Ends
I did see the FAQ. It wasn't really clear about doing them under the cleanout port, though. I'm thinking about moving forward into the engine compartment, but put them before the "Y" fitting. There's not much hose there so I'm seeing if I can move things around a bit so that the valves will fit up there.
I also mic'd the hose... it's exactly 15mm I.D.
That'll work... thanks @MOA_Chaser just keep us up to date on how it goes.
