ChrisM
- Rock HIll, SC 29730
- Chaparral
- VR
I would definitely disagree. That's not a valid reason to discourage against BRP propulsion plants.
Going forward from at least 2008 BRP changed the carbon seal to a larger one.
My 3 BRP platforms have been trouble free for years. @ 100 hours I performed the required maint on the RXP which includes driveshaft maint, and carbon seal inspection. It was clear that the driveshaft was due for spline lube, and I electively replaced the carbon seal, boot, and the other parts while in there. Engine mounts are critical too, if not checked seasonally, and there is excess movement, or broken this will directly impact the carbon seal and it's ability to seal.
My Exact PWC. This one sank due to worn engine mount.
