Cory
- Lake Kiowa, TX 76240
- Limited S
So are you saying using the long RCA's isn't a bad idea?
This true in many home audio systems that do not have input gain control. But do you know of a specific brand or model that has it AND ALSO is suitable for marine audio applications?Actually the better amplifiers will have a buffered pass-thru so the RCA 'out' is driven by its own OP amp. It's easy enough to verify with a multimeter.
Totally understand that. My situation is the opposite, ropes and fenders and other wet thing in the back. My helm is the driest area on the boat so it gets the towels, chips, and most of the electronics.Cost isn't really the issue for me, I just like the idea of having the amps in the back, as we store all the ropes and fenders in the helm compartment and I don't want everything getting wet in there.
Related question, my head unit has a single RCA plug for subwoofer, where as my sub amp has both a red and white. Do I only hook up to the white, or do I put in a "Y" and hook to both?
And if a "Y" which end do I put it on? "Y" at the head unit and run a double RCA wire, or run a single wire and "Y" at the amp?
